 Post subject: bios detect WD1600AAJS to ROM MODEL-PINCLITE
PostPosted: October 21st, 2010, 5:47
Hello
Blue label WD1600AAJS-22L7A00 has problem
bios detect it ROM MODEL-PINCLITE.
so i tried swap head & fix pcb.
but same result.
i think it's not problem of head & pcb
may be sa problem...
anyone knows solution of this?
plz help.
 Post subject: Re: bios detect WD1600AAJS to ROM MODEL-PINCLITE
PostPosted: October 21st, 2010, 9:04
Hee wrote:
Hello
but same result.
plz help.
Yes , for this family , SA problem is often meet .
Angel Data Recovery
PostPosted: October 21st, 2010, 17:09
Hee wrote:
Hello
but same result.
plz help.
If you swap heads without do the WD alignment, don't expect different result....
Janos
PostPosted: October 23rd, 2010, 23:08
Hee wrote:
Hello
but same result.
plz help.
Until you actually know what is the problems in this drive then do not replace the heads on it. Once opened the alignment becomes an issue on this one. What do you mean you fixed the PCB? What was wrong with it and what makes you think it is heads on this one. Now it is open your chances of recovery have droped to 0 to -50 on this one. Sorry but now a recovery company needs to help you out on your drive and the price has now gone up. A simple recovery with proper diagnoses could of saved your data and money on this one in the long run. Your drive your data your choice. Good luck.
Iorana Haraharaini
PostPosted: October 25th, 2010, 4:17
Ann is right here, you have now complicated what was potentially a straightforward SA problem.
Now you have only one solution - professional service.
Users browsing this forum: fouad19764, Google [Bot] and 156 guests
