 Post subject: Raid 5 Question
PostPosted: October 27th, 2010, 9:43
Trying to work out the parity on a 4 disk raid 5
Drives are 500GB Seagate, w/ Adaptec controller.
3rd disk in the physical array failed and got replaced, on rebuild the whole thing failed. It was then initialized but not formatted
I have imaged all disks, the physical 4th disk had bad sectors (probably why it didnt rebuild but DDI got a perfect clone)
Array was 1.36TB and I know the Block size to be 256kb, Raid re constructor will only entertain a Parity of Backward 3-2-1. It give insignificant results for anything else.
However, on scanning the VIM Image I get a good file structure of the D:\ Partition and all the folders but...only small docs are ok, everything else will not open.
Would that suggest that the parity is wrong totally ?
thanks in advance
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: Raid 5 Question
PostPosted: October 27th, 2010, 15:02
Raid reconstructor is not that good for damaged raid sets. I think winhex and some serious sector checking is the only solution.
Dobre
Murphy was an optimist
PostPosted: October 28th, 2010, 4:15
Backwards is standard for Adaptec RAID. Also, as RR gives OS:4, I guess is NTFS. Manual identification of config from sectors should allow good build in Winhex or r-studio. should not be too complex.
PostPosted: November 1st, 2010, 11:12
thanks guys, winhex did the trick (after alot of trial and error)
merci
andy
PostPosted: November 1st, 2010, 11:23
Good work!!!
Users browsing this forum: fouad19764 and 172 guests
