 Post subject: How can I hack wd smartware unlock?
PostPosted: November 8th, 2010, 17:10
How can I bypass the password which the user set to his external WD drive?
I succeed to have access to the drive but nothing can be do till I enter the right password.
How can I hack this unknown password? (except of geting the right password from the user).
Regards,
 Post subject: Re: How can I hack wd smartware unlock?
PostPosted: November 8th, 2010, 17:21
I have played with this one quite a bit, unless someone else out there has learned something that I missed, it's not something that can be done.
PostPosted: November 8th, 2010, 17:39
In other words, it's the most powerfull encryption that can't be hack?!
PostPosted: November 8th, 2010, 17:42
If you can crack 256-bit encryption, then you may be able to get the data,, but if this is a 2.5" passport then there are additional complications as well.
PostPosted: November 8th, 2010, 17:48
What are the additional complications without the encryption?
What do you actually saying? that if one forgot his password the drive is useless forever?!
It can't be format again and ofcourse that the data is gone?
sounds weird.. :?
PostPosted: November 8th, 2010, 18:00
Isn't there an option to format and reset the password?
PostPosted: November 8th, 2010, 18:22
Yes there is an option to format the drive, erase the password, and lose all data. It pops up when you type in the wrong password too many times in a row.
PostPosted: November 8th, 2010, 18:45
Shhhhhhhhh top secret.
There is a trick to this crypto code.
What you need to do is connect the drive to your PC and then
"CALL THE USER FOR THE PASSWORD"
PostPosted: November 9th, 2010, 15:53
good one guru , :D
Users browsing this forum: fouad19764 and 172 guests
