 Post subject: Seagate Cuda ES.2 500gb not firmware ? mac user
PostPosted: November 8th, 2010, 14:56
hallo all -
new to the site outta necessity - and a mac user ..
barracude ES.2 500gb s/n 9QM0FX7T ST3500320NS - Seagate tells me this is not a firmware issue as shipped 26 Dec '07 after firmware fix in house -
drive worked great for 1.5 years - next day would no longer boot or recognize - have some data would like to try to recover myself as low on scratch
HD spins in 2 different computers as well as hard case - just does not recognize or boot
peeked about on site but have not seen anyone talking about recovery using a Mac
anyone have some wisdom to share ?
cheers in advance
 Post subject: Re: Seagate Cuda ES.2 500gb not firmware ? mac user
PostPosted: November 8th, 2010, 18:18
Search for terminal report on seagates.
Post here what you get in the terminal, then we'll have a better idea.
Murphy was an optimist
PostPosted: November 9th, 2010, 15:50
say dobrevjester:
cheers for the reply ;
Do you mean to say try an communicate with the HD thru a terminal window ?
if so - i gotta figure this action out
cheers:
PostPosted: November 9th, 2010, 16:21
Correct. Its allready explained several times in this forum.
Use search function.
Dobre
PostPosted: November 11th, 2010, 6:32
For information on how to obtain a terminal report, see the following thread:
http://forums.seagate.com/t5/ATA-and-Se ... 036#M19464
The ES.2 drives that are affected by the BSY bug will respond to the abovementioned 7200.11 DIY fix, but with a slight twist:
http://www.msfn.org/board/topic/129551- ... 0cc-state/
To communicate with the drive via its serial port, you need the Mac equivalent of a terminal utility such as HyperTerminal or PUTTY.
Users browsing this forum: fouad19764, Google [Bot] and 153 guests
