 Post subject: HDD Motor
PostPosted: November 9th, 2010, 19:53
Hi all, I once resurrected my Seagate hard drive by using the hyperterminal guide. It all went well after that but has failed again a few months later ( not being recognised by bios). I tried the routine again but it failed performing the Spin Up command. Now I can't do anything with it.
All that happens is that the motor is receiving short voltage pulses to the spin motor (each half second On-Off-On-Off). On an old sata drive I am measuring +4.7V on each of the three pins of the PCB to the motor, with respect to ground. I want to test the spin motor by using an external power supply. Would I need to connect a 5V supply to ALL three leads to test spin or just one or two. (I'm thinking that maybe one of these leads are used for a type of feedback for revs monitoring or something.
Anyone's input on how this works is most appreciated and you can get as technical as is required, thanks.
 Post subject: Re: HDD Motor
PostPosted: November 11th, 2010, 7:08
Measure the resistances between each pair of motor terminals. There should be three phases. The resistance of each phase winding is about 3 ohms, so phase-to-phase should be about 6 ohms.
See the following datasheet for information on how to drive the motor.
L7250, SMOOTH, spindle motor + VCM controller, ST Microelectronics:
http://www.datasheetcatalog.org/datashe ... Xyuswx.pdf
Users browsing this forum: fouad19764, Google [Bot] and 177 guests
