 Post subject: Seagate momentus 5400.3 80 GB problem
PostPosted: November 11th, 2010, 21:26
Seagate Momentus 5400.3 80 GB
MDL: ST980811AS
FIRMWARE: 3.CDD
I did head stack replacement, the hdd is ready but now the disc is recognized with another model, serial and firmware.
Please see image
 Post subject: Re: Seagate momentus 5400.3 80 GB problem
PostPosted: November 12th, 2010, 2:19
Did someone 'touch' the pcb?
PostPosted: November 12th, 2010, 2:56
Plug your numbers into Seagate's warranty validator:
http://support.seagate.com/customer/war ... dation.jsp
Compare the date code on the label against the YWW (Year / Week) date codes on the chips.
Seagate date code calculator:
http://www.bugaco.com/calculators/seagate_date_code.php
I believe the date of manufacture may also be stored in the SA.
PostPosted: November 12th, 2010, 5:32
STRONZATE (Bullshit).
There are many things to "do" with a PCB / drive without touching a screw, the OP is a pro.
PM sent. ;)
PostPosted: November 12th, 2010, 12:28
the hdd is blocked...
PostPosted: November 12th, 2010, 13:11
Yes but according to what we have talked about..... ;)
PostPosted: November 12th, 2010, 16:01
BlackST wrote:
the OP is a pro.
Even so-called pros can benefit from the advice of lesser mortals, as you well know from personal experience.
PostPosted: November 12th, 2010, 16:39
I think the drive is password protected , remove password and see what happens.
PostPosted: November 12th, 2010, 19:57
The eventual lock is the lesser/last problem... Was the rest fixed?
PostPosted: November 18th, 2010, 17:57
The PCB is not original.
PostPosted: November 18th, 2010, 23:33
what did I tell you?
PostPosted: November 21st, 2010, 4:19
What you said was that "there are many things to 'do' with a PCB / drive without touching a screw".
PostPosted: November 21st, 2010, 5:25
In pm not in public, I am not fool to feed you . :mrgreen:
Users browsing this forum: No registered users and 166 guests
