 Post subject: help identifie donor samsung usb hdd drive
PostPosted: November 26th, 2010, 6:08
how identifie hdd donor from this Samsung hard drive:
Model HM500LX
Hdd PN:HM500LX/VPK
S/N:81VV1JDQS10613
I do the change head
Thanks!
 Post subject: Re: help identifie donor samsung usb hdd drive
PostPosted: November 26th, 2010, 6:28
How about starting by a drive with same model?
But to be honest, if you're asking that question, you're probably not very experienced in swapping heads no?
PostPosted: November 26th, 2010, 7:19
Indeed I am not very experinced from heads change
PostPosted: November 26th, 2010, 7:28
So what will happen is that you'll waste your money in the parts, loose your data, and in the end, if the data is important, you'll take it to a data recovery company, and they will charge you much more because you messed it up.
If your data is valuable, you should check a data recovery company to make you a quote.
Users browsing this forum: Google [Bot] and 131 guests
