Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: RAID5 - HP Smart Array E200, failed drive.
PostPosted: November 25th, 2010, 17:24
For the rebuild of your the key is the MFT Records, in NTFS.
PostPosted: November 26th, 2010, 6:28
Thank You, DR-Kiev, unfortunatly this config doesn't seem to be correct :/
I had 1st parity moved to secound compund in my description that You quoted becouse thats what x-rays forum member suggested.
About this ntfs record I found them only at 2nd drive (1st is not present) other 2 hdds dont contain such record. I assume this can be a lead in how stipe distributes the data though.
I will try with defrent delays since from what i've seen on the google hp has 8 or 16 delay. I'll post info of the results when I complete.
PostPosted: November 26th, 2010, 6:56
Uploaded with ImageShack.us
Another attempt:
- Forward parity, starting from secound compund - 128 sectors (64kb) stripe
(exactly what the x-ray member said, since his post is inconclusive he said that this controller doesnt follow regular hp delay scheme but he didn't clarified if it uses it or not...)
PostPosted: November 26th, 2010, 7:00
RAID doesnt rebuild out of the box but with this setting with 16kb stripe i get some readable directories in found partitions, ill scan more to see what it finds.
PostPosted: November 26th, 2010, 9:03
Check PM
Angel Data Recovery
Users browsing this forum: No registered users and 167 guests
