 Post subject: Problem with Seagate Barracuda 7200.9
PostPosted: February 9th, 2011, 12:45
Windows was failing at installing the drivers for my external HDD, it is a Maxtor one touch III, so I took it apart and extracted the drive. I then connected it to a computer and it could not recongize the drive. The drive sounds fine physically so I am beginning to think that the circuit board may be bad on it.
Here is all the specs I can find about it
S/N: 5NF2HZYT
ST3300622A
P/N: 9BD044-326
Firmware: 3.AAK
Data Code: 07053
Site Code: WU
The circuit board is
100368182 Rev A
Any help is greatly appreciated.
 Post subject: Re: Problem with Seagate Barracuda 7200.9
PostPosted: February 9th, 2011, 12:47
Its not a circuit board problem.
www.datarecoveryne.com
PostPosted: February 9th, 2011, 18:36
Do you have any idea what is wrong with it then?
PostPosted: February 10th, 2011, 2:01
Could be many reasons, can't tell exactly unless proper diagnostics are done.
Do you have terminal output?
PostPosted: February 11th, 2011, 2:00
There is a slim chance that the PCB may have a problem on the IDE interface.
You can buy a replacement PCB for US$30 plus $10 for a firmware transfer:
http://www.onepcbsolution.com/seagate-b ... 43263.html
PostPosted: February 11th, 2011, 15:53
Im not familiar with how to obtain the terminal output, is there a post here explaining it?
PostPosted: February 12th, 2011, 18:56
If you don't have the tools, how will you repair the drive?!?!
ACELab partner
PostPosted: February 13th, 2011, 14:14
Well I need to diagnose what the problem is first.
Users browsing this forum: Google [Bot] and 194 guests
