 Post subject: 7200.11 Heads swap problem
PostPosted: March 16th, 2011, 11:42
Hello
We have problem with transplanting heads on 7200.11
we have donor
- same firmware
- same country
- same model
but the disk is not ok after swaping heads
a strange noises come from hdd
what's the problem?
Same problem we had with other ones
 Post subject: Re: 7200.11 Heads swap problem
PostPosted: March 16th, 2011, 12:11
What is wrong with original heads?
Where is terminal output?
www.datarecoveryne.com
PostPosted: March 19th, 2011, 5:41
Preamplifier was bad.
Why doesnt work transplantating heads on 7200.11,
as i mentioned same donor.
PostPosted: March 19th, 2011, 6:34
do heads back to donor work ?
PostPosted: March 20th, 2011, 5:28
yes
heads back in Donor works
PostPosted: March 20th, 2011, 7:36
Probably it is not spinning enough fast.
What kind of noises? What says terminal?
Angel Data Recovery
PostPosted: March 20th, 2011, 7:40
Ditto... Shift or not reaching target speed maybe !
PostPosted: March 20th, 2011, 9:19
sound like trrrrrrrrrr
did you have success with changing heads on 7200.11
The original heads sounds, like repeated calibration, maybe one head is damaged\
but with new heads we get no sounds like before at all.
Users browsing this forum: Google [Bot] and 115 guests
