 Post subject: RAID 5 xfs Iomega StorCenter
PostPosted: April 11th, 2011, 8:38
Hi everyone,
I need some help, I have an IOMEGA StoreCenter 150D using RAID 5 and XFS filesystem.
I think the RAID configuration is good, because with a manual reconstruction of the volume using R-Studio I can recover files in good shape.
But on the UFS-Explorer with the same configuration it only shows and empty root folder.
Has anyone see this before....?
 Post subject: Re: RAID 5 xfs Iomega StorCenter
PostPosted: April 11th, 2011, 9:37
If u are able to recover files using R-Studio then why do u want to use UFS Exp ????
PostPosted: April 11th, 2011, 9:45
Hi ROb
Because with R-Studio we lost filesystem structure.
Thanks for your reply
PostPosted: April 11th, 2011, 12:17
rootk!t wrote:
Hi everyone,
You do something wrong. May be you should update you UFS.
And try to miss every drive to find best.
Angel Data Recovery
PostPosted: April 12th, 2011, 7:29
Hi DR-Kiev
Like you said, I tried with the last version of UFS and also set disks to missing, but I still got the same result, the root folder is empty.
Any other thought....?
