 Post subject: Re: Samsung HD080HJ repair
PostPosted: April 17th, 2011, 17:23
Samsung 80Gb HDD F / W ZH100-47
Hard drive scans all of the time, krrr krrr. Why is it scans? Installing Windows. Initially, the procedure was started, and suddenly krrrr, krrr. I did a reboot, Windows will not load up anymore. Says that Windows is not installed. Hard drive shows error # 732. Disk has bad sectors. Are the bad sectors can be repaired? Is the FW update will help? S.M.A.R.T is turned off. I do not know why?
PostPosted: April 18th, 2011, 5:31
0x01 smart error!
PostPosted: April 19th, 2011, 4:06
Your problem description is vague.
Try a comprehensive SMART diagnostic. Look for reallocated, pending, or uncorrectable sectors.
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/
HDDScan for Windows:
http://hddscan.com/
See this article for SMART info:
http://en.wikipedia.org/wiki/S.M.A.R.T.
PostPosted: April 19th, 2011, 4:34
The problem is simple, instead .
It can be a firmware problem , head problem or surface problem.
In all the case above, without the necessary K-H and equipment it is impossible to fix it completely.
Moreover it is a 80GB drive, rather old and with a value of 10$ if not less on the aftermarket.
PostPosted: April 19th, 2011, 5:33
Buy a new drive.
PostPosted: April 19th, 2011, 17:09
I wrote in haste. After I read myself, and did not understand, sorry. I enclose a picture. The disc is full of bad sectors. ~ 4 days and I've improved a little more behind. I do not know whether the sectors will be lost or come back?
File comment: Prior to the restoration of 15% for 20-30 thousand a bad sectors. Now it is 37% at 6 thousand Bad Sector. Will restore disk and I can use?
PostPosted: April 19th, 2011, 17:27
If this was my drive and I didn't know much about data recovery, I would download a hirens bootcd and scan with mhdd in DOS.
PostPosted: April 19th, 2011, 17:30
Useless. The problem is elsewhere.
PostPosted: April 19th, 2011, 17:34
What do you mean?
PostPosted: April 22nd, 2011, 2:29
I guess I'll buy you a new one.
SAMSUNG_HD080HJ_S08EJ1NP304123_ZH100-47-surface-full.jpg [ 670.24 KiB | Viewed 7832 times ]
PostPosted: April 22nd, 2011, 13:09
Can I upgrade F / W?
PostPosted: April 22nd, 2011, 14:06
Useless.
P.S. either the explanations are not clear or what you hear is not what you want to hear . Once for all :
1) The drive may have a surface problem (degradation) and you need specific knowhow AND/OR equipment and resources to perform technical procedures to fix it (if possible, and depending what happened eithere these procedures will fail and the drive has to be discarded). I CAN'T TELL NEITHER GIVE YOU ANYTHING.
2) You can also have another problem and in this case the drive has reached EOL.
3) The drive is a small, old (>5 years old most probably) drive that has a value of 10$ or less. Instead of trying to repair itand use it = make a time bomb of it as it will fail soon due to mechanical EOL, get a new drive.
Users browsing this forum: Majestic-12 [Bot] and 67 guests
