 Post subject:
PostPosted: August 20th, 2003, 19:09
Hi Monolit, well well we have here someone that can help us, finaly.
Ok, I have some doubts, and i saw that you are an expert, in hard disks maters; so I would like to askyou some help, if is possible of course.
First I hear that to fix drivers ( and fix drivers is not only record a firmware ) we need to know ATA commands, this is true ?
And to start to fix them the first thing that we have to do is: put then in "Factoring Repair Mode", is this true ?
And them we can start to make a diagnoses, is this true ?
Also I hear that we do not need to buy PC3000 and HRT, because we can make the utils suing the ATA supercommands, is this true ?
And you say that the PC3000 and the HRT is only to record firmwares, so you know how to fix the others problems, no ?
Like G-List, P-LIst; SMART failling, Passwords, and other small problems that we see in the hard disks, M'I wright ?
So if this is all true; could you - please - help us, mortals ?
Best regards
Jose Pinto
 Post subject:
PostPosted: August 21st, 2003, 7:02
[quote="jmuanes"][/quote]
Hi!
>>is true ?
Yes, it's true, but these ATA commands is vendor specific ATA commands and may be various even for different drives of the same manufacturer.
Only for some hard drives. For example, the Fujitsu and quantum hard drives enters that mode automatically, when one or few modules of "diskware" (it's part of firmware, located on the media platters) is damaged. When will damaged the Flash ROM on Fujitsu HDD's, hard drive enters the "Kernel Mode", and ready to receive only commands for read/write the Flash ROM.
Yes.
>>because we can make the utils suing the ATA ??
Yes, if you know this supercommands, there is no problems, but if you don't know one, it's very difficult work, you need to disassemble firmwaries, firmware update utils etc, you must understand, how it work and what is what there, in order to find and get supercommands.
Not completely. PC-3000 is bad utility for IBM HDD, at least in v.11. It does not fix serious firmware problems and password problem in newest IBM HDD's, one useful feature - disconnection of damaged heads, is not useful for IBM HDD's, because in this HDD's if one head is damaged, all other heads after some time will damaged too. HRT is more better and can fix any problems with firmware etc. However, problems with reallocated sectors in the SMART, bad sectors on the media, and transfer defects from user list to factory list, can be fully done by freeware DFT utility from http://www.hgst.com.
Best regards,
Michael.
 Post subject:
PostPosted: August 22nd, 2003, 5:28
Hi Michael, thanks a lot for your atention and answer.
So could you say what we can do to learn more and how we can do to help ourselfs when we have problems with hard disks?
Best regards
Jose Pinto
 Post subject:
PostPosted: August 27th, 2003, 9:34
Is true pc3000 v11 for IBM is a little "slow", I try this my self. what obout v12 or the updated util is anyway better?
Regards,
format_b.
 Post subject:
PostPosted: September 1st, 2003, 22:19
Thank you so much for your explanations,Monolit.Thank you!
Users browsing this forum: Majestic-12 [Bot] and 61 guests
