 Post subject: Error adding defect to slip list 7200.12 seagate
PostPosted: May 21st, 2011, 1:50
hi,
i have a model 7200.12 st3320418as. it has translator problem. i did run translator recovery command. but stops at a some sector . error is translation fork abmiquity, correct it manualy. so i tried to add defect to slip list. but i get error in terminal.
Hard reallocate LBA status:error = 00000002:04808781.
i treid several bad sectors to sliplist but same error
i tried G6C command but i get same error. i cant add sectors to sliplist. i tried Glist clearing.
thanks in advance
pls help me
 Post subject: Re: Error adding defect to slip list 7200.12 seagate
PostPosted: May 21st, 2011, 7:44
What are you using for that, as tools?
ACELab partner
PostPosted: May 23rd, 2011, 1:32
helo pclab,
i am using pc3000 udma utility .
Users browsing this forum: Bing [Bot] and 187 guests
