 Post subject: WD4000AAJS - bad head swap?
PostPosted: May 19th, 2011, 22:49
I was able to image about 60% of the drive, but there were huge chunks that would not image and caused the drive to go busy. I swapped the heads and hooked up the drive to Atola to get the rest. However, now the drive is quietly clicking 3 times and then powering down. I am using the DRT alignment tool, but can't seem to find the sweet spot. My questions are:
1. Does this series drive have huge alignment issues - Tornado 2R series I believe?
2. Is there a way to determine if the head swap went ok, or if I just have to work with the alignment jig more?
Shawn
 Post subject: Re: WD4000AAJS - bad head swap?
PostPosted: May 19th, 2011, 23:20
This does not really have special alignment issues, like most of the pre-royals do. Clicking and powering down means that one or more heads is bad, or is a mismatch.
http://www.datasaversllc.com
PostPosted: May 19th, 2011, 23:45
Thats what I was afraid of. The donor appears to be a good match, both match on full model/firmware data, DCM's are:
DHRCNT2MHB
DHRNHT2AHB
Looks like I will be sourcing another donor and getting the 'right' head tool.
PostPosted: May 23rd, 2011, 23:11
Update - I switched the original heads back onto the patient and the drive became ready and let me image the rest of the drive out (actually about 98%).
I believe the donor drive was a good match and I just botched the swap somehow. However, the interesting thing is that I was able to image the rest of the drive AFTER putting the original heads back on the original drive. As Jon indicated, there were no alignment issues.
Users browsing this forum: No registered users and 163 guests
