 Post subject: Seagate Galaxy 2D pending problem - solution not working
PostPosted: May 24th, 2011, 11:21
Hi all,
So I have a ST3500630AS (3.AAK) 7200.10 which is suffering from the 'pending' bug. Now I've fixed at least 3 or 4 of these drives in the past with this same problem, the loader solution worked fine. But this drive is a different story.
I have tried the 'normal' pending solution by using loader, but as soon as I've copied a few thousand LBAs the bug comes back and terminal starts giving pending output again. I've played with the extended settings in the task creation in DE but no luck. The drive sounds perfectly healthy, and IDs fine. Loader was created without any hassles. If I wait long enough (about a minute) after starting it up with the loader, I can see the folder structure in DE, but copying anything just goes horribly slowly and with IO errors.
Any advice would be appreciated. I've received certain advice that said I should try a different PCB and/or heads if the loader doesn't help, but I don't want to go down this route (yet?). After starting up with the loader I can image about 130,000 LBAs very fast, and then the bug stops me again. I'm hoping there's a solution for this (that someone is willing to share with me).
Reset
8192k x 16 DRAM
GALAXY - 1_Disk S-7A 12-08-06_16:41
Buzz HM SFI
(P)SATA Reset
carve writesAT Er 00 Nwt Er 37 RdWr 042dd.02.004f
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b8 97f29ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 0042dd.02.004f
CE Log ErrCode=37 LBA=9ace5fc Type=5 Add To Pending 9ace5fc
AT Er 00 Nwt Er 37 RdWr 042dd.02.005c
Niwot: 9ff79ff7 b8 9ff79ff7.3.640 0000 005f 0000 0000
CE Log ErrCode=37 LBA=9ace609 Type=4 Remove from Pending 9ace609
CorrectWriteStart
AT Er 00 Nwt Er 36 RdWr 042dd.02.005c
Niwot: 09ace5fd 14 09ace5fd.0.018 000d 3642 000d 0000
CE Log ErrCode=36 LBA=9ace609 Type=0 Remove from Pending 9ace609
AT Er 00 Nwt Er 37 RdWr 042dd.02.007a
CE Log ErrCode=37 LBA=9ace627 Type=4 Remove from Pending 9ace627
etc, etc, etc.
Data Recovery Cape Town
 Post subject: Re: Seagate Galaxy 2D pending problem - solution not working
PostPosted: May 24th, 2011, 15:53
You have PM
PostPosted: May 25th, 2011, 7:52
An update on this drive. First, thanks to pcimage for some advice with this case.
It turns out that this drive has head issues as well. I'm busy imaging the drive with heads 0 to 5, with 2 disabled and it's almost complete. Once that's done and I've done a few other things, I'll replace the faulty HSA and get the rest of what was needed from head 2.
Users browsing this forum: No registered users and 175 guests
