 Post subject: Disk imager
PostPosted: May 26th, 2011, 13:52
Hi to all! :D
Disk Imager copy king from SD is good??
This tool is good for clone hds with bads blocks?
Please info for members!!
Thanks!
Нет ничего невозможного
 Post subject: Re: Disk imager
PostPosted: May 26th, 2011, 14:22
This is not suited for HD with bad sectors. Check out the one from Atola.
PostPosted: May 26th, 2011, 14:28
Sempre, I've seen you on the ACE forum so I assume you have DE. Do you not find it works well if configured correctly?
What about DDI - too expensive?
Data Recovery Cape Town
PostPosted: May 26th, 2011, 14:40
Yes, ACE forum!
I have DE.
I wanted a second option to not be busy with pc3k long hd cloning with many bads blocks
PostPosted: May 26th, 2011, 14:47
Yeah I know what you mean. Imaging a big drive with bad blocks can take ages and if you're using a PC3K port then you can't use it for working on other drives.
I really want to get a DDI but I can't afford one just yet, maybe sometime later this year.
PostPosted: May 26th, 2011, 14:52
Easy buy other Udma
ZeBong
" Россия еще раз"
PostPosted: May 26th, 2011, 14:54
First I must win the lottery :lol:
PostPosted: May 26th, 2011, 17:40
My impression of DCK is that its an overly expensive imager for good working drives. It seems suited for the IT person who need a mobile imager. Save your $$$ for a DDI.
PostPosted: May 27th, 2011, 9:54
It seems to me that the Atola imager be a good option...?
PostPosted: May 29th, 2011, 2:08
Atola imager is the best tool to go for
it has some really nice add ons
not seen in other tools on the market
and you can custom it in the setup
target all data on the drive and it will target all folders
i seen in forums where people having problems with the copyking not that great to much money does not do what it suppose to do :(
PostPosted: May 31st, 2011, 4:37
I like to combination PC3000 with HDD Duplicator
Users browsing this forum: No registered users and 37 guests
