 Post subject: flash rom to swap on 7200.12
PostPosted: June 1st, 2011, 7:43
Anyone know if 7200.12 series has got flash rom on pcb?
the original pcb is burnt.
 Post subject: Re: flash rom to swap on 7200.12
PostPosted: June 1st, 2011, 7:49
get ur self a donor pcb
2nd. as one of my close friends (seagate expert) told me once, Follow the White Rabbit..
you should find 2 identical chips in ur pcb, one of them is the ROM, need to find it ur self
and move it to donor PCB
good luck
PostPosted: June 1st, 2011, 8:33
I would imagine that the chip I've circled is the one you need to swap. Perhaps someone else can confirm.
Data Recovery Cape Town
PostPosted: June 1st, 2011, 9:20
Yes that's the one....
Rgds
www.datasave.ro
PostPosted: June 1st, 2011, 9:46
just to confirm dont they normally start with 25?
Think I remember reading that here somewhere.
PostPosted: June 1st, 2011, 9:47
Circled chip starts with 25, you can see if you zoom into the image.
PostPosted: June 2nd, 2011, 1:41
My HDD IC database should help:
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
Users browsing this forum: No registered users and 34 guests
