 Post subject: Ever seen a problem like this?
PostPosted: June 7th, 2011, 8:30
Scenario - I had a PC with 2 HDD. Both were 250GB drives.
C:/, master primary, had 50GB used
D:/, master slave, had 100GB used. (150GB free.)
So, now then.
I was planning to format + reinstall Windows onto C:/, right? Easy enough. So, I went ahead, loaded the disc in, booted to disc, got to the screen where you select drives to install / format, partition, etc... Right? So, I clicked C:/, and formatted it. It formatted perfectly.
Now, I do not exactly remember, I may have seen that D:/ was affected somehow when I formatted C:/, or it may have been after I installed windows to C:/, but either way, after formatting C:/, my D:/ drive was showing as a 150GB disk. Not 250GB with 100GB used, and 150gb free space, but a disk showing a toal of 150GB size.
errrrr
edit: I have not written any data to the disk since this has happened. I think it was powered when I booted to windows, where I checked the disk properties and saw the disk size as 150gb within windows, but i didnt write anything to it. after seeing that, i removed the disk from my pc and ya its been sitting here for a year.
 Post subject: Re: Ever seen a problem like this?
PostPosted: June 7th, 2011, 16:32
You can download a free trial of Get Data Back or R-Studio and see what they can find, if you like what you see, you can pay to activate them and have full access to what you saw.
You may need a 'USB to IDE/SATA adapter' off ebay, be sure to get the one with the power supply.
Depending on what version of Windows and how you formatted, results may vary.
Dave
Users browsing this forum: Majestic-12 [Bot] and 31 guests
