 Post subject: Matching WD PCBs
PostPosted: June 10th, 2011, 11:57
I have a WD800 that appears to have a bad PCB. I also have a WD400 that has a good PCB. What I want to know is, since both PCBs have the same numbers 2060-001130-012 REV A, would swapping out U12 work, or do I need to get a board from the same size drive...
I can't seem to locate an answer by using the search tools here so I thought I'd ask...
Thanks in advance
WSDigital...
 Post subject: Re: Matching WD PCBs
PostPosted: June 10th, 2011, 12:54
Theoretically, that should work.
Users browsing this forum: Majestic-12 [Bot] and 31 guests
