 Post subject: PC fell on side, Hard Drive OS is gone
PostPosted: June 15th, 2011, 13:41
My PC fell over onto its side the other day while I was downloading some stuff. Now Windows 7 doesn't load at all and trying to repair shows no OS anymore. When I slave the drive I can't see any partitions or data. But when I run "Recover My Files", It detects all my data with names intact. Is there some way to repair the partition or OS? Or is the hard drive actually damaged?
 Post subject: Re: PC fell on side, Hard Drive OS is gone
PostPosted: June 15th, 2011, 13:52
Need more advanced, data recovery like, diagnosis. Meaning, must test the read-write components to see if they do work as they should.
Have experience or any tools?
PostPosted: June 15th, 2011, 14:06
The drive likely now has bad sectors and possibly failing heads. If your data is important to you, I suggest that you stop powering the drive on and have it assessed by a professional data recovery lab. Your drive may have limited life left and you don't want to lose your data while it is still recoverable.
PostPosted: June 15th, 2011, 14:58
In My Computer the drive letter is there but nothing else, and in Computer Management the drive is: RAW (file system), Healthy (Active, Primary Partition). That would suggest that only the bootable part of the hard drive is messed up.
I do have some experience with doomed hard drives. Which tools would you suggest?
PostPosted: June 16th, 2011, 1:33
Well, the drive officially died. Made some bad clunking sounds and one of the chips burned. I got all the data that I needed I think from my recovery program.
Thanks for the help though
Users browsing this forum: No registered users and 184 guests
