 Post subject: Toshiba MK1652GSX Problem
PostPosted: August 11th, 2011, 5:03
Images 100% perfect, came out an HP Laptop
Recovery partition looks ok but system partition only raw, no file structure using all the main ones R-stud,GDB,UFS
Im thinking security encryption software, customer says no
any ideas
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: Toshiba MK1652GSX Problem
PostPosted: August 11th, 2011, 5:09
Use entropy to check encryption
Lemmy
PostPosted: August 11th, 2011, 5:12
im googling :)
PostPosted: August 11th, 2011, 6:21
@buster80: A few comments...
FYI HP did bundle encryption s/w (SafeBoot, I think) with their laptops, at least for a while (though that doesn't prove whether this was in use in your case, of course). As ici_lemmy says, looking at the entropy of the "filesystem" gives a hint...
I would also look at the MBR and following few sectors (it's usually a special MBR for SafeBoot or other "full disk encryption" systems) - unless the customer has overwitten the MBR (and perhaos following sectors) during their "attempts" to fix the problem before you got involved. Therefore IMHO it is vital for the customer to give you a full and exact history of what happened, and what they did in response so far.
PostPosted: August 11th, 2011, 6:24
Thats helpful Vulcan, client said it just chucked it and I.T had a quick look before passing it on.
No secrets or anomalies although I'm skeptical as its very strange
cheers for that reply , going to open it up in winhex and post a screenshot
PostPosted: August 11th, 2011, 6:31
With winhex, you can also do "Analysis disk" (F2)... It will read all sectors and if a the graph is flat --> encryption
Lemmy
PostPosted: August 11th, 2011, 6:32
nice, thats handy :)
PostPosted: September 1st, 2011, 11:50
HP does have security software which encrypts user partition.
Working right now on a drive with such encryption.
Anyone have suggestions or hints?
www.datarecoveryne.com
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 82 guests
