 Post subject: HP security software that encrypts user partition.
PostPosted: September 1st, 2011, 12:08
I have a drive from HP which has Data partition encrypted.
Was able to image 80% of that drive.
Boot partition is fine, but have to decrypt data partition.
Any suggestions or hints are welcome.
www.datarecoveryne.com
 Post subject: Re: HP security software that encrypts user partition.
PostPosted: September 1st, 2011, 13:37
get the decryption credentials from the client
If it is a hardware encryption through an enclosure, place the clone back into the enclosure.
PostPosted: September 1st, 2011, 15:07
Its an internal drive
PostPosted: September 2nd, 2011, 9:24
What kind of encryption?
Pointsec, Bitlocker, PGP...
THey should have those credentials if it was used. If it is a corporate drive they may not release that info.
Have you tried booting the clone up to see if maybe it will authenticate through boot. I know this may or may not work due to hardware differences from the clients computer, but worth a try. Then you may get lucky and just need the clients username and password for windows.
PostPosted: September 3rd, 2011, 7:28
I have seen a number of these with Safeboot pre-installed. Can you see any references to "SAFEBOOT" at the start of the drive?
Data Recovery Ireland
Users browsing this forum: No registered users and 106 guests
