 Post subject: WD5000AAKS
PostPosted: September 6th, 2011, 19:07
I am experiencing an issue with an external hard drive, wd5000aaks. When hooked up over USB the drive begins to load but then I hear not necessarily clicking, but a noise as it were about to spin up and then immediately fails. This happens over and over for about 30 seconds and then stops. After it stops, if I go into drive management in Windows 7 it recognizes the disc but says that it has not been initialized. If I take the drive out of the case and connect it directly by a SATA cable the files show up but it brings the whole computer to a crawl and whenever I try to copy the files it eventually fails.
Any suggestions as to what might be the problem? I have an extra donor PCB board, but it's a 2060-701537-004 while the broken board is 2060-701537-003. I wasn't sure if trying a swap could cause additional damage so I haven't done anything yet.
Thanks in advance for any help!
 Post subject: Re: WD5000AAKS
PostPosted: September 6th, 2011, 19:11
When you connect the drive directly by SATA, you ear it start spinning? That what happens? Do you ear knocking noises? Spindle stops or continues rotating?
PostPosted: September 6th, 2011, 19:19
It makes the same noise when connected over SATA also. It does appear to continue spinning though.
PostPosted: September 6th, 2011, 19:41
Well, that may indicate different issues, like SA problems, ROM, Heads.
You need to take it to a pro for a proper diagnosis.
PostPosted: September 6th, 2011, 19:57
Its either a read/write head issue or a lot of bad sectors.
If your drive is still recognized by a computer, it should not cost you "an arm and a leg", may be one of those at worst.
Many forum members could offer inexpensive recovery, just let us know where you located and we'll refer you to a closest one.
www.datarecoveryne.com
PostPosted: September 6th, 2011, 20:00
That would be great. I am located near Atlanta, GA, USA.
Thanks!
PostPosted: September 6th, 2011, 20:02
Jono-ats, is one of very reputable members of this forum and located in Atlanta, GA.
http://www.datasaversllc.com
Users browsing this forum: No registered users and 91 guests
