 Post subject: Need some assistanse with dead FUJITSU MHY2160BH HDD
PostPosted: September 8th, 2011, 12:05
Hello everyone!
I have a dead hdd FUJITSU MHY2160BH, CA06889-B377000T. The platters won't spin and I'm pretty sure the PCB is fried so I need some guidance to swap the PCB.
HDD Details are:
Serial ATA
Made in Thailand
Model: MHY2160BH
Part# CA06889-B377000T
SER: K428T7B281VA
160GB
Board # on PCB CA26344-B32104BA
Board Laber# VCP7YQ8L26
Date: 11/30/2007
My question is, does the PCB needs to have the same exact specs? I found this one online but the numbers are kind of different. Can I still use this PCB?
FUJITSU MHY2160BH, CA06889-B036 (Mine is B37)
Board # on PCB CA26344-B32104BA (The same as the defective one I have)
Board number on label: VCP7X6NLFC ( Different from mine)
DATE: 10-16-2007
My apology's if this is not the right place to ask for this.
I will appreciate any assistance on this....
Thanks!
 Post subject: Re: Need some assistanse with dead FUJITSU MHY2160BH HDD
PostPosted: September 8th, 2011, 12:25
You would be very lucky if after PCB swap you could access data.
One need to swap ROM also, if it's external.
PostPosted: September 8th, 2011, 12:37
Thank you for your response :)
It is a 2.5 laptop HDD. Do I still need to swap the ROM as well?
PostPosted: September 8th, 2011, 12:46
I could only tell by checking the PCB.
Post a picture here.
PostPosted: September 8th, 2011, 14:05
I'm currently at work but as soon I get home I post the picture for you.
Thanks!
PostPosted: September 8th, 2011, 15:56
This is the HDD PCB. Thank you for your help! :)
PostPosted: September 8th, 2011, 16:29
Can you remove the gray cover and picture it again.
PostPosted: September 8th, 2011, 18:10
Sorry, will do later on.
Users browsing this forum: No registered users and 93 guests
