 Post subject: Firmware or hardware fault - ST3500410AS
PostPosted: September 19th, 2011, 2:52
Hello all.
I have a Seagate ST3500410AS.
On power on, the drive spins up, makes a dozen or so ticking noises like the heads are moving, and then the drive powers down about 15 seconds after the initial power up.
Would this most likely be a firmware fault for this model?
Thank you for any help you can provide.
Josh
 Post subject: Re: Firmware or hardware fault - ST3500410AS
PostPosted: September 19th, 2011, 3:00
without proper diagnose/tools difficult to solve
but probably heads
PostPosted: September 19th, 2011, 3:12
Agree with einstein9, 9/10 gonna be bad heads with those symptoms on that model.
PostPosted: September 19th, 2011, 3:25
Thanks for your advice einstein9 and pcimage.
I appreciate it.
I just noticed now that the drive eventually spins up again, and then starts making a fairly quiet but fairly nasty scraping sound.... :(
So I'd say your advice is spot on.
Thank you both.
Users browsing this forum: No registered users and 91 guests
