 Post subject: WD800JB-00CRA1 Board Failure
PostPosted: October 7th, 2011, 8:00
Good day all I’m looking for a little help, and I’m a new so please be patient...
Can any one provide a list of possible serial boards that will also work with this drive (WD800JB-00CRA1) the original board has a power surge and fried the board...?
Any help is very much appreciated, please note I’m looking to swap the board as my soldering skill are not that good and I cannot tell which chip has gone !..
Many thanks for reading the above I look forward to your kind help, thanks.
Wayne
 Post subject: Re: WD800JB-00CRA1 Board Failure
PostPosted: October 7th, 2011, 8:49
There are a few things to consider when your PCB is damaged:
- Sometimes you can swap the board with a suitable replacement whilst moving across some adaptive info which is stored on an 8-pin ROM chip. Other times this info is stored in the main controller so moving it over to the replacement board isn't viable. Specialist equipment is required.
- If the damage was bad enough it could have damaged some internal components as well, requiring more than just a replacement PCB. Professional assistance is required.
- In certain circumstances it can be as simple as removing a shorted protection diode, ensuring your power supply is 100% and then pulling off your data.
It's best to take a quality photo of your PCB, component side up, so that members can help you.
Alternatively you can contact a professional in your country, forum member pcimage.
Data Recovery Cape Town
PostPosted: October 7th, 2011, 8:59
Thank you for you timely responce the board doesent look damaged at all however it just does not power up. The broblem stems from a loose power cable in the cady i think so was hoping it was just a PCB. Ill post a couple of pics in a few hrs many thanks for your responce.
Wayne
Users browsing this forum: Majestic-12 [Bot] and 63 guests
