@Vulcan, thanks, here the SMART raw that you needed , i hope this can give you more information,
Hard Disk Summary Hard Disk Number,1 Interface,S-ATA II Disk Controller,Standard Dual Channel PCI IDE Controller (ATA) Disk Location,"Channel 1, Target 1, Lun 0, Device: 1" Hard Disk Model ID,MAXTOR STM3250820AS Firmware Revision,3.AAE Hard Disk Serial Number,6QE1S03D Total Size,238472 MB Power State,Active
Logical Drive(s) Logical Drive,F: [coba]
ATA Information Hard Disk Cylinders,484521 Hard Disk Heads,16 Hard Disk Sectors,63 ATA Revision,ATA/ATAPI-7 Total Sectors,488397168 Bytes Per Sector,512 Buffer Size,8192 KB Multiple Sectors,16 Error Correction Bytes,4 Unformatted Capacity,238475 MB Maximum PIO Mode,4 Maximum Multiword DMA Mode,2 Maximum UDMA Mode,300 MB/s (6) Active UDMA Mode,300 MB/s (6) Minimum multiword DMA Transfer Time,120 ns Recommended Multiword DMA Transfer Time,120 ns Minimum PIO Transfer Time Without IORDY,120 ns Minimum PIO Transfer Time With IORDY,120 ns ATA Control Byte,Valid ATA Checksum Value,Valid
Acoustic Management Configuration Acoustic Management,Not supported Acoustic Management,Disabled Current Acoustic Level,Default (00h) Recommended Acoustic Level,Max performance and volume (FEh)
ATA Features Read Ahead Buffer,"Supported, Enabled" DMA,Supported Ultra DMA,Supported S.M.A.R.T.,Supported Power Management,Supported Write Cache,Supported Host Protected Area,Supported Advanced Power Management,Not supported Extended Power Management,Not supported Power Up In Standby,Not supported 48-bit LBA Addressing,Supported Device Configuration Overlay,Supported IORDY Support,Supported Read/Write DMA Queue,Not supported NOP Command,Not supported Trusted Computing,Not supported 64-bit World Wide ID,Not supported Streaming,Not supported Media Card Pass Through,Not supported General Purpose Logging,Supported Error Logging,Supported CFA Feature Set,Not supported CFast Device,Not supported Long Physical Sectors (1),Not supported Long Logical Sectors,Not supported Write-Read-Verify,"Supported, Disabled" NV Cache Feature,Not supported NV Cache Power Mode,Not supported NV Cache Size,Not supported Free-fall Control,Not supported Free-fall Control Sensitivity,Not supported
SSD Features Data Set Management,Not supported TRIM Command,Not supported Deterministic Read After TRIM,Not supported
S.M.A.R.T. Details Off-line Data Collection Status,Successfully Completed Self Test Execution Status,Successfully Completed Total Time To Complete Off-line Data Collection,430 seconds Execute Off-line Immediate,Supported Abort/restart Off-line By Host,Not supported Off-line Read Scanning,Supported Short Self-test,Supported Extended Self-test,Supported Conveyance Self-test,Not supported Selective Self-Test,Supported Save Data Before/After Power Saving Mode,Supported Enable/Disable Attribute Autosave,Supported Error Logging Capability,Supported Short Self-test Estimated Time,1 minutes Extended Self-test Estimated Time,92 minutes Last Short Self-test Result,Never Started Last Short Self-test Date,Never Started Last Extended Self-test Result,Never Started Last Extended Self-test Date,Never Started
Security Mode Security Mode,Supported Security Erase,Not supported Security Erase Time,Not supported Security Enhanced Erase Feature,Not supported Security Enhanced Erase Time,Not supported Security Enabled,No Security Locked,No Security Frozen,Yes Security Counter Expired,No Security Level,High
Serial ATA Features S-ATA Compliance,Yes S-ATA I Signaling Speed (1.5 Gps),Supported S-ATA II Signaling Speed (3 Gps),Supported S-ATA Gen3 Signaling Speed (6 Gps),Not supported Receipt Of Power Management Requests From Host,Not supported PHY Event Counters,Supported Non-Zero Buffer Offsets In DMA Setup FIS,Not supported DMA Setup Auto-Activate Optimization,Not supported Device Initiating Interface Power Management,"Supported, Disabled" In-Order Data Delivery,Not supported Asynchronous Notification,Not supported Software Settings Preservation,"Supported, Enabled" Native Command Queuing (NCQ),Supported Queue Length,32
Disk Information Disk Family,DiamondMax 21 250820 Form Factor,"3.5"" " Capacity,"250 GB (250 x 1,000,000,000 bytes)" Number Of Disks,2 Number Of Heads,3 Rotational Speed,7200 RPM Rotation Time,8.33 ms Average Rotational Latency,4.17 ms Disk Interface,Serial-ATA/300 Buffer-Host Max. Rate,300 MB/seconds Buffer Size,8192 KB Drive Ready Time (typical),11 seconds Average Seek Time,8.5 ms Track To Track Seek Time,0.8 ms Full Stroke Seek Time,? ms Width,101.6 mm (4.0 inch) Depth,147.0 mm (5.8 inch) Height,21.0 mm (0.8 inch) Weight,600 grams (1.3 pounds) Acoustic (Idle),2.5 Bel Acoustic (Min performance and volume),3.2 Bel Acoustic (Max performance and volume),3.2 Bel Required power for spinup,"2,800 mA" Power required (seek),12.4 W Power required (idle),8.9 W Power required (standby),0.8 W Manufacturer,Seagate Corporation Manufacturer Website,http://www.seagate.com/maxtor/
| Attachments: |
File comment: using harddisk sentinel
