seagate st9120817as, very slow cloning
October 26th, 2011, 13:41
I've got similar problem to
seagate-7200-st3250624a-t10711.html
SMART shows a few hundred bad sectors.
The problem is it scans well in MHDD (shows some UNC and S). Average speed is 40MB/s.
While making the clone (DMDE), copying speed is incredibly slow - 1MB/min.
The same result when using ATOF in MHDD.
Is there a way to speed it up ?
Re: seagate st9120817as, very slow cloning
October 26th, 2011, 14:19
probably bad sectors or weak dying heads
October 26th, 2011, 14:30
Then why scaning in MHDD is fast ?
October 26th, 2011, 14:44
u will need proper tools my friend to handle this case
+ u will need to know what ur doing
October 26th, 2011, 16:02
Maybe it is "like that" with what you have, so "forcefully" you have to stick with it. Behaviour may be different with HW cloning tool OR ...............
Anyway if you can clone it "slowly" but safely, it's better than nothing .
October 27th, 2011, 6:02
I thought it could be bypassed somehow.
October 27th, 2011, 8:03
The problem is Windows in combinations with the drive's firmware bug and bads.
In order to maximize recovery efforts, meaning getting a good image out of the drive and of course as fast as possible, you have to work outside of Windows.
Now there are various degrees of effectiveness for each tool as not all can resolve the problem.
What non-windows tools do you have available? Or willing to buy?
October 27th, 2011, 8:10
I work in DOS scaning(MHDD)/cloning(DMDE/MHDD), so Windows behaviour is not a problem
October 27th, 2011, 10:11
laptokowiec wrote:I work in DOS scaning(MHDD)/cloning(DMDE/MHDD), so Windows behaviour is not a problem
the way windows detects/reads hdd`s is totally Diff. than Pro. tools
for some hdd`s windows cannot even identify it, but Pro. tools will do
hope u got my point here
good luck
October 27th, 2011, 10:17
But I've already written that I don't work in Windows.
October 27th, 2011, 10:49
@laptokowiec:
As I understand your description, only MHDD Scan is "fast"; other actions which you have tried (MHDD ATOF, DMDE cloning) are "slow".
There are other tools you could use (Media Tools Pro, or ddrescue under Linux/Unix), which would provide data about which other tests report different speeds, but I see one likely difference from the information you have given so far..: MHDD Scan uses the ATA Verify command; however your attempts to read the disk's data into the host for cloning (e.g. MHDD ATOF and DMDE Cloning) do not use the ATA Verify command (because that does not transfer data to the host!), and instead they must use the ATA Read command.
Therefore if I was in your situation, I would focus on a possible slow host interface, as the cause of the speed difference which you are reporting, since the disk/media is the same in your tests. The Read speed seems even slower than PIO mode (!), but at least I would check to see what host I/O mode had been negotiated, and see if a different mode can be set (e.g. hdparm in Linux).
It's just a thought, based on the information you have given :)
October 27th, 2011, 19:43
I am not familiar with DMDE... what kind of tool is this? How does it work?
October 27th, 2011, 22:12
First hit with Google ...
http://www.google.com/search?q=dmde
October 28th, 2011, 3:15
Vulcan: Thanks. I'll try hdparm.
labtech: DMDE - in my opinion very good software
October 28th, 2011, 10:26
And what about "Add To Pending" in terminal ?
I think it could slow the cloning.
Is there a way to stop/repair it ?
October 28th, 2011, 10:41
This has all been completely addressed already in the other thread
pcimage wrote:CE Log error
FW Issue, needs resolving with PC3000 or Salvation.
dobrevjetser wrote:Ace's UDMA can handle this in the utility settings in DE.
Best regards,
Dobre
It has nothing to do with Windows, or PIO mode, or any of that
October 28th, 2011, 11:31
I wish I had read the linked thread before now - this thread does seem to be a bit of a re-hash :(
Of course the drive is sick. Nevertheless, I don't see an explanation of why ATA Verify & Read commands to the same media (hopefully to the same LBAs, if the test is being done correctly) appear to behave so differently. While I could conjecture about that (without mentioning PIO etc. :) ), it would be interesting if anyone actually knows why there is such a difference, as reported by the OP.
October 28th, 2011, 11:46
I've read it could be solved by p3k or salvation tool, but I still belive' it could be done in terminal mode.
Maybe some sort of 'stop/reset: add to pendind' could be executed?
October 28th, 2011, 16:24
After 3 hours of TOF in MHDD it suddenly sped up.
I checked the 'pending sectors' in SMART. It reached about 4000.
When I've turned off the system and started it again, the slowness returned.
SMART showed about 40 (pending sectors).
So I figured I'll try the same and see what'll happened.
I run TOF and after about 3 hours it sped up :-)
SMART - about 4000 pending sectors.
It looks that filling the 'pending sectors' position in SMART unsolves the problem.
