 Post subject: CPR Head Tools
PostPosted: November 15th, 2011, 20:25
Wanted some feedback on the CPR headcombs for use on a WD1200BB. I believe the headcomb for this model is PC06. There is a ridge on the inside of the drive case that makes removing head 0 with the HDRC combs nearly impossible. Essentially the design of the HDRC tool pushes head 0 down too much and it comes into contact with the ridge on the case. Does the CPR headcomb have a similar problem? There is very little clearance available, so wanted to know if others had a hard time with replacing heads on these drives.
 Post subject: Re: CPR Head Tools
PostPosted: November 16th, 2011, 7:56
anything on the compatibility list ?
they are pretty good on the email, you could ask them as its an older drive
Andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
PostPosted: November 20th, 2011, 19:29
I do not think anybody on this forum had luck with HDRC
HddSurgery - Professional Data Recovery Tools
