 Post subject: Seagate head INcompatibility
PostPosted: November 22nd, 2011, 16:41
Got a Seagate Momentus in for recovery. Drive is ST9500420AS with D0005SDM1 firmware. Head 1 reports back as bad with Atola. Turned that head off and imaged the rest of the drive perfectly. Ordered a new drive, however firmware was 0003SDM1. Everything else matched up. Switched heads and drive just clicks, spins down and repeats.
Thinking that there was an incompatibility with firmware, I ordered a new donor with everything matching (firmware, site code, first 3 char. of SN). After swapping heads, the patient just clicks, spins down and repeats. Moved back heads to their originals and everything is back - no clicking on patient or donor.
Am I missing something here as far as headstack compatibility is concerned (yes or no is fine)?
Pesky
 Post subject: Re: Seagate head INcompatibility
PostPosted: November 22nd, 2011, 16:53
From what I can see your donors are a good match. Personally I've had luck matching model only, different site codes. Have seen stories of swaps with different model numbers even. Your patient probably has some other underlying problem.
I have also heard instances of perfectly matched donors and no luck with headswap (talking Seagate here).
My luck has been good with matching model, site and first 3 of S/N. However, talk about a large capacity .11 and it's not that simple...
The thick plottens.
Data Recovery Cape Town
