 Post subject: Swapping 2.5" platter
PostPosted: November 28th, 2011, 10:16
Hi all Gurus,
I have a 2.5" 125gb Fujitsu hard drive that is dead showing no signs of life or anything on bios.
I also have a fully working 2.5" 250gb Toshiba hard drive.
Would it be possible to swap the platter from the faulty Fuji into the Tosh as i need to get some data off?
I am a newb to HD internals your help would be appreciated :D
 Post subject: Re: Swapping 2.5" platter
PostPosted: November 28th, 2011, 10:21
Unequivocally no.
I suggest that you contact Pcimage from this forum, for recovery help in your region.
Jon
http://www.datasaversllc.com
PostPosted: November 28th, 2011, 10:29
I understand the drives are different data sizes but surely the platters are the same physical size and fitment. they are not stacked platters there single layer. would they not read the same like putting in different cd's in a disk drive look for zero and start..?
PostPosted: November 28th, 2011, 11:19
jono-ats wrote:
Unequivocally no.
Jon
I agree, contact Pcimage.
PostPosted: November 28th, 2011, 11:31
un·e·quiv·o·cal (n-kwv-kl)
adj.
Admitting of no doubt or misunderstanding; clear and unambiguous: an unequivocal success.
une·quivo·cal·ly
adv.
in an unambiguous manner
Just in case that wasn't clear:
No! No! A Thousand Times No!
PostPosted: November 28th, 2011, 11:48
i agree ... NO
platter physical size is not enough...
there are many good pros in UK if you need to recover data
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: November 28th, 2011, 12:09
will not work 100%
If you attempt this you will fail, and most likely cause the drive to forever unrecoverable by any means.
If the data is important, take it to a pro for a proper diagnosis
PostPosted: November 28th, 2011, 12:41
Thanks for the responses. Data recover is far to expensive. The motor does not spin up so i think it could quite possibly be the PCB faulty which is easy enough to replace as long as i get the maching model and firmware, correct?
PostPosted: November 28th, 2011, 13:27
Wrong =(
You will need to transfer adaptives on this disk. You *may* be in luck and find the ROM to be external, but on the newer Fujitsu they began to embed into MCU.
PostPosted: November 28th, 2011, 13:33
Again, no. Sorry. Pcimage or hddguy can do it for you. If it is only the pcb, it shouldn't be THAT costly.
PostPosted: November 28th, 2011, 14:15
Here are your options, as I see it.
1. Give up, lose your data and save your money
2. Try DIY, lose your data and lose your money
3. Try PCImage, save your data and lose your money
I cannot speak for PCImage, but most labs give a free quote. If you find the quote by the pro too much, then you can decide between #1 and #2.
PostPosted: November 28th, 2011, 15:25
Option 4
Get a quote & if its too much then place the drive in a draw somewhere safe until you can save the money
PostPosted: November 29th, 2011, 2:49
loki wrote:
Option 4
This one is a good option, IMHO
Users browsing this forum: Google [Bot] and 60 guests
