 Post subject: Broken USB Connector
PostPosted: December 12th, 2011, 15:30
Question guys
if you look @ the 2 places where the USB mini goes which is Broken connector
i tried to follow the points trying to solder ext. wires to it, but the problem is that it is too damn tight
even i tried to pull a wire from the 2 points but too damn small hole
my question is: is there any soldering material which fills those empty broken places (brown) ?
or any other technique?
thank you
 Post subject: Re: Broken USB Connector
PostPosted: December 12th, 2011, 16:05
wirewrap wire
PostPosted: December 12th, 2011, 16:06
Hi, I would have thought for recovery purposes you can solder directly to what look like 2x inductors. Not sure what the other component is closer to the 2 broken pads but it might be a ferrite bead.
It dosn't look too hard from here! You just have to use the good magnifying lamp, the correct tip on your iron & a good quality solder. Maybe use kaynor wire though not always necessary.
PostPosted: December 13th, 2011, 4:34
thank you guys, will go through it again
my soldering skill were so bad, but now big Diff. heheh
thnx again
Users browsing this forum: Google [Bot] and 69 guests
