 Post subject: Western Digital World Edition XFS
PostPosted: December 13th, 2011, 12:03
I have I really bad situation. A broken enclosure with 2 drives (RAID 1) using XFS file system. 1 drive didn't start up cause of powerfailure from the enclosure but span up with a different.
Here's the problem, the working drive only contains system folders from the NAS-system, but the 'user'-area is blank.
Viewing in HEX only 0000000, the same with the broken one. It's journal-based so if I'm not misstaken it is using 256mb in a special partition and this partition belonged to the 'broken' area of 1 drive.
Even if it was created in a non x86-arch it should be visible in HEX?
Best regards
Bob
 Post subject: Re: Western Digital World Edition XFS
PostPosted: December 13th, 2011, 13:26
Sure it was Raid1 ?
Find XFS boot , and mount it with Linux or with UFS explorer to check .
ABout 00000 in user area , sure you have checked all space?
For XFS it is normal, some valuable data could be stored even near at the end of the storage .
Angel Data Recovery
PostPosted: December 13th, 2011, 15:42
Yes, checked the logfile using the UFS explorer to see wich RAID. The zeros, seen more than just one drive with this. This is the second NAS-system with the same problem. The last one using SPARC zfs. The UFS explorer together with HEX, I'm able to see the partition with root folders for the linux-system itself but no user data. All space checked, still 0000, only very small pieces of information.
PostPosted: December 14th, 2011, 4:37
does mybook world encrpyt data?
PostPosted: December 14th, 2011, 5:25
Doesn't matter, cause the encrypted data should still be visible in HEX. Cannot remember if the encrypt the data, only software then I think.
Best regards
Bobby
PostPosted: December 14th, 2011, 9:48
The encryption on WD works through USB Bridge, the NAS units do not use USB so I assume is not with encryption.
Users browsing this forum: fouad19764, Google [Bot], Majestic-12 [Bot] and 52 guests
