 Post subject: retrieve data from corrupted RAW Sata (EXT3)
PostPosted: December 23rd, 2011, 10:13
Hello guys,
I really need help here...
I have slaved and auto mounted 1TB HD in my Ubuntu system. Now, my system has crashed and I tried to backup data and files in the HD. Generally speaking, the HD is already an ext3 type. When I try to open it using windows, HD is read as RAW. How to save the data available in the HD?
I've tried using easus and other recovery file... but still, no hopes... well at least easus can read the data inside but didn't manage to backup the data..
Thanks in advance..
 Post subject: Re: retrieve data from corrupted RAW Sata (EXT3)
PostPosted: December 23rd, 2011, 10:18
First I would recommend understanding why the system crashed to ensure there are no problems with the HDD other than the corruption you mentioned. MHDD can help you with this to get a general drive status.
If HDD checks out ok, then run R-Studio demo.
PostPosted: December 23rd, 2011, 11:13
http://sourceforge.net/projects/ext2fsd/
PostPosted: December 23rd, 2011, 23:44
Thanks for the feedback...
Ok, the scenario here getting worse actually ...
When i try to boot up.. first thing first ... it stated... "Secondary Master... Error"
and even the disk management cannot read my hard disk ... :( ..
Any suggestion here ??
p/s : well, basically ...the hd become unreadable now.... via sata.... via network storage...
PostPosted: December 24th, 2011, 3:36
just an add on ... I try to check the status of my disk ... using teskdisk .. it won't read my hd... I don't want to put an assumption if it's a hardware failure... yet ..
PostPosted: December 24th, 2011, 17:12
Does it show up in BIOS and/or device manager with correct model?
PostPosted: December 24th, 2011, 21:21
Nope..... So what does it mean
but when i try to use sata to usb.. It showed up as an unknown devices in the disk management and cannot be initialize
PostPosted: December 26th, 2011, 5:41
labtech,
do you think it's a hardware failure?
PostPosted: December 26th, 2011, 10:27
High chance, yes. But more testing by a professional is necessary. And I mean a reputable DR company.
PostPosted: December 26th, 2011, 20:21
How about placing my hdd in the fridge ?
PostPosted: December 27th, 2011, 4:09
Why, do you plan to eat it later?
If your drive is recognized in Bios, you can try to use R-Studio to scan and retrive your files.
Bosse
http://www.rescue-it.se
PostPosted: December 27th, 2011, 5:02
Nope it doesn't showed up in bios...
PostPosted: December 28th, 2011, 21:40
No, not going to solve anything, but just make things worse potentially.
This is a misnomer that is not applicable in modern hard disk drives.
Users browsing this forum: gold6565, Google [Bot] and 102 guests
