7200.11 after spindle replacment
January 2nd, 2012, 9:22
** 7200.11 1500GB ** (ST31500341AS)
Received that drive that falled down and motor was seized, so i went into spindle replacment
now the motor spin free, but the drive is not responding, try a head swap and all i got is :
Rst 0x20M
than nothing ( heads still try to do domething but no terminal messages )
by isolation the pcb do NOT give me ctrl+Z ready. ( i try also on another drive same model and also there does not give ctrl+Z ready)
Re: 7200.11 after spindle replacment
January 2nd, 2012, 13:39
Maybe alignment issue. How did you free up motor? Does the drive click?
January 2nd, 2012, 13:40
northwind wrote:Maybe alignment issue. How did you free up motor? Does the drive click?
i swapped spindle bearing of the motor.
Drive rumble a bit , yes.
January 2nd, 2012, 22:24
Sent pm.
