server can't boot
January 2nd, 2012, 7:10
hello, i'm new here,,happy new year for all
i've prblm on my hp dl360 server 4 disc raid 10, with poor handling, the server does not recognize any partition, unfortunately it is a mail server (backup), pleas help
thank you
Re: server can't boot
January 2nd, 2012, 7:43
I would go by steps.
First of all, mark all drives, remove them from the server and test them individually.
After that, you need to identify which drives belongs to what and separate the 2 RAID0 individually.
After that, you have to rebuild the 2 RAID0 and compare them.
January 2nd, 2012, 9:08
Suggest you here: Dr.Kiev the RAID Master here
he is the one
good luck\
January 3rd, 2012, 11:42
I try to change hard disk, but still do not see partitions
January 3rd, 2012, 11:49
Please be a little bit more specific than that.
January 4th, 2012, 4:04
I replace the disk one after another by another disc that is in good operating.
what you mean to remake the raid?
January 4th, 2012, 4:07
and how to separate between the 02 RAID ?
thank's
January 4th, 2012, 4:33
You have to know how to analyze the drives at low level and understand the data on them.
Based on that you can separate the 2 RAID0.
January 4th, 2012, 11:12
@kamou18
Also, rebuilding (or "remake" as you mentioned) the RAID is not a good idea as it means jeopardizing the data integrity.
You have to first identify what is wrong with each drive. You may have more than one drive failed.
This is a really difficult DIY - it seems - based on the questions you asked.
January 5th, 2012, 5:07
Where are you based kamou18 ?
