Samsung Burn In
January 5th, 2012, 9:01
I have specific question about you guys who has better understanding about Samsung Burn In Test...
PM is also appreciated
1. Differences between HT and HTBI Code
2. After uploading Fflash to HDD, SHOULD I RESET POWER?
Hard Reset or Soft Reset? Plug/Unplug power?
3. For the BI_SCRIPT module - should I write all HEX CODE to ZERO (0) ?
or specific few HEX Code to ZERO (0) ?
4. If I require Head Cut, should I cut directly
or need to configure something? Suppose Primary Head - Head 0 is bad,
then should I cut it directly? Will the drive work after doing that?
