cloning software
January 10th, 2012, 5:33
Hi i swapped head on a WD pcb USB 2,5 and i would like to clone it but all my PC3000s are busy in some long recovery.
Somebody have never tried a software for cloning that can use forward-backward direction and create a map of sectors read/unread ?
Re: cloning software
January 10th, 2012, 8:22
Hi, is your system powerful enough to supply power for 5 drives simultaneously ?
January 10th, 2012, 8:49
freakzy wrote:Hi, is your system powerful enough to supply power for 5 drives simultaneously ?
this depends on power supply.
with my 500W cooler master i already tested 6 drives without problem.
what take power in a moderm computer is indeed the GPU, that in data recovery is not needed.
Explain me your question..
January 10th, 2012, 10:02
positivebit, check your PM.
January 10th, 2012, 10:10
@positivebit:
There have been previous discussions of cloning software in the forum. Do you really need a map of sectors read/unread (e.g. a graphical display of some kind), or do you just need the software to keep a record of those sectors? Do you need the forwards/backwards selection to be automatic, or can you cope with that selection being a manual choice?
Depending on your answers, then ddrescue under *nix might fill your needs (depending on the health of that drive, after the head replacement, of course). I don't know whether other cloning software (DMDE, Media Tools Pro etc.) include the options you have requested.
January 10th, 2012, 10:13
Thanx to Vulcan and to all that has sent PM,i will give a try to softwares, including ddrescue.
@ freakzy: nice suggestion - clever.
:lol:
January 11th, 2012, 6:42
Try Hd Duplicator , with the help of adapter supplied it can power on /off drive & can clone in forward /Reverse .
