 Post subject: Is it possible to undelete files on Netgear Readynas Ultra2?
PostPosted: January 12th, 2012, 6:35
First post :)
Last week I bought a RNDU2000 NAS, currently it is running two 3Tb hitachi hard drives in RAID0 mode. Problem is I accidently deleted some files (approx 70 movies totalling 750Gb) without setting up recycle bin, and now I can't get them back. I know with normal RAID0 array it is possible to run some third party software which will scan the drives and recover the files, however it seems the Netgear NAS utilises some sort of proprietary RAID array that these third party software do not recognise.
One option is to take the NAS to a data recovery specialist, however these guys charge a premium for their service (something like $600 per drive!) which is way over what the deleted files are worth...
Is there anything else I can do? The hardware are in perfect condition and I haven't copied any new files to the NAS since the files were deleted.
Thanks for reading. As appreciation for your help I am offering a $150 "reward", via paypal, to the person who can provide me with a step by step guide to get the files back that works)
 Post subject: Re: Is it possible to undelete files on Netgear Readynas Ult
PostPosted: January 12th, 2012, 8:20
I think the data probably still is present on your media, but because file system is most likely Journalled recovery from 'Undelete' process will not work. Only identifying data based on its file signature may work.
What data was deleted? What types?
PostPosted: January 12th, 2012, 9:37
Another Simple idea to try:
Network MAP the NAS, then Scan it
should get them back
"Think Different" I like this MAC Slogan.
PostPosted: January 12th, 2012, 9:39
forgot to mention
try replacing existing Hitachi hdd`s with WD much easier for disaster recovery later
i HATE Hitachi drives really, had bad experience with it
PostPosted: January 12th, 2012, 10:23
You cannot treat a mapped network share as a device that can be scanned.
This will not work...
PostPosted: January 12th, 2012, 10:32
Online
I was thinking the same thing...
But it may be possible to use a cross over cable and connect the device directly to your computers NIC. Not sure that method will work to scan either.
The best thing to do is to clone them both, hook up both clones to your computer ( through SATA), rebuild the raid config with the two drives, (with UFS Explorer) then scan for deleted data. I know this is the most extreme method , but it may get your Files back.
Unless someone knows a Deleted file recovery software that will scan a network drive.
PostPosted: January 12th, 2012, 11:18
This would probably be the safest option.
If the storage device is mapped through iSCSI, then I should think normal file recovery software would work.
"EaseUS Data Recovery Wizard Free Edition, compatible with Windows 2000/XP/2003/Vista/2008/Windows 7, can recover lost files due to deletion, format, raw partition, virus attack, system crash etc. from iSCSI drive, external hard drive, hardware RAID, hard drive, USB drive, SD card, memory card, etc."
Note: I have never used this product.
PostPosted: January 12th, 2012, 11:44
Make sure you find out if your NAS has an Ext3 or Ext4 filesystem, not all recovery products support Ext4 (I don't think EaseUS Data Recovery Wizard Free Edition does support Ext4).
PostPosted: January 12th, 2012, 14:20
some time ago, i was looking for such a UTILITY that does treat USB hdd as a Eth.
and i did found it. do not remember the name exactly but i found it
then
i came up with the vise verse option, and again I FOUND IT
this might be very good also. and for newbies who dono
btw, i remember very well that i got the portable ver. of BOTH mentioned Util. very easy
squeezing my brain to remember the name so far.
and hddguy ur right, i just tried it on mine did not work. :wink:
PostPosted: January 12th, 2012, 15:41
I use "USB over ethernet" utility
That's the name :D
PostPosted: January 13th, 2012, 5:15
R-Studio supports Ext4. And you may try it before buy.
R-Studio Data Recovery Software
PostPosted: January 13th, 2012, 6:14
Thank you so much for all your suggestions, for a newbie like myself I will try out Rstudio first, will follow up with results soon... :?
PostPosted: January 13th, 2012, 6:36
I recall on a journaled EXT filesystem (ext3 or ext4), there is a requirement like
for a journaling to work, inodes must be zeroed when deletions are committed to the disk. This pretty much eliminates all the chance for easy undelete, leaving only raw scan for a non-fragmented files.
PostPosted: January 13th, 2012, 7:10
:good:
Users browsing this forum: Google [Bot] and 164 guests
