 Post subject: WD5000KMVW-11ZSMS0 reading instability
PostPosted: January 20th, 2012, 12:03
Hello
I have a WD5000KMVW-11ZSMS0 that is detected but after after couple of seconds lose connectivity(The drive never shut down, keeps spinning), after a minute start working again for 3 to 5 seconds(time to recognize the drive and see the partition) before losing connectivity again. This continues to happen repeatedly.
I open the drive and check the heads individually under microscope and they seem to be in perfect condition.
For now I don´t have a spare drive to start making some tests.
Someone already had the same kind of issue? any tips?
Thanks everyone :)
 Post subject: Re: WD5000KMVW-11ZSMS0 reading instability
PostPosted: January 20th, 2012, 12:17
what equipment u runing it on m8 ?
PostPosted: January 20th, 2012, 12:48
Hi Alex :) long time
I´m using PC3000
PostPosted: January 20th, 2012, 13:24
Did you check usb connection? More than often these get loose, maybe you've got some loose contact.
PostPosted: January 20th, 2012, 14:57
hmm , i have very limited experience with native USB boards unfortunately. If the drive keeps on recalibrating under PC3K environment - ima at a loss. I would however blame physical connection like Northwind suggests first.
PostPosted: January 21st, 2012, 9:05
Thank you for the tip northwind.
I tried to force USB connection several times until one of the attempts he remained connected. I am recovering the data.
Thanks a lot for your help guys :)
PostPosted: January 21st, 2012, 18:39
Excellent :) Good job!
