 Post subject: Hitachi 1 tb p/n: 0f10383
PostPosted: January 21st, 2012, 20:56
I have damaged part of the PCB by allowing it to touch part of the pc case and it sparked and frazzled part of the board. Would i be be able to get the same model 1tb Hitachi drive and swap over the pcb to recover my data? Thanks.
 Post subject: Re: Hitachi 1 tb p/n: 0f10383
PostPosted: January 22nd, 2012, 10:14
Not without at least copying/moving over the NVRAM.
PostPosted: January 22nd, 2012, 11:59
Thank you very much for your reply, please could you point me in the direction of instructions for this procedure, I think this maybe beyond my skills.
PostPosted: January 22nd, 2012, 18:36
Use the search function using keywords such as "NV-RAM", "solder", " Hitachi adaptive", etc.
Plenty of info available to get clarification.
PostPosted: January 24th, 2012, 18:14
There is an 8-pin chip that needs to be transferred from your original PCB to the replacement PCB. Your local TV/AV repair shop should be able to do the soldering for you.
