Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Another WD 2TB 20EARS green issue - ABRT on all sector r
PostPosted: February 2nd, 2012, 11:16
BTW I had a 2tb a little while ago. Close problems. No sector access some modules screwed. Got a good hot swap donor , fixed up the mods need fixin , recalculated the translator and still aborts on all sectors. Then ,on a whim, i ran the PC3ks 1 button solution to solve slow responding problem. And suddenly it worked =) Might wanna take a look into what that thing does. Clears up some garbage with pending bads i think.
PostPosted: February 2nd, 2012, 11:29
Mostly the slow responding solution applies only to cases where sectors can be read, but is good to know it worked in your case :)
PostPosted: February 2nd, 2012, 11:33
I tried this already but it didnt work out.
I do not consider myself as a pro. :)
PostPosted: February 2nd, 2012, 12:13
I was talking to Yaroslav from Deepspar after , he was as surprised as me =) But , hey it did work =) Although like i said i DID have to fix up some modules manually before that =)
PostPosted: February 2nd, 2012, 12:14
Hey =) i was poking fun at myself actually =) U can be a pro with 1 post =) Or a spammer with no actual knowledge with over 9000 =)
PostPosted: February 2nd, 2012, 12:18
Agree. :good:
