 Post subject: A hard disc capacity question
PostPosted: February 7th, 2012, 13:20
I have a LG NAS model N2A2DF2 4TB. It uses 2 Hitachi HDS72292 drives, each spec at 2TB capacity. Yet when I look at the unformatted capacity using the NAS interface, the capacity is shown as 1.8 TB for each or 3.6 TB combined for both drives.
Shouldn't the capacity is 2TB unformatted for each drive?
Many thanks.
 Post subject: Re: A hard disc capacity question
PostPosted: February 7th, 2012, 13:26
This is because there are actually two different systems used in relation to storage media, binary and decimal. Binary identifies 1 KB as 1024 bytes, while decimal identifies 1 KB as 1000 bytes.
The storage 'standard' will always use decimal
PostPosted: February 7th, 2012, 13:41
@webbeing:
FYI you can read some of the background of what hddguy explained here:
http://en.wikipedia.org/wiki/Gigabyte
This is quite an FAQ in the storage area, so there are other places you will find info, if you want to read more...
@hddguy:
:good:
PostPosted: February 7th, 2012, 15:20
Speaking of FAQs ...
http://www.users.on.net/~fzabkar/HDD/HD ... y_FAQ.html
What the HDD manufacturers say ...
Storage Capacity Measurement Standards [194563]:
http://seagate.custkb.com/seagate/crm/s ... cId=194563
Drive displays a smaller capacity than the indicated size on the drive label:
http://wdc.custhelp.com/app/answers/detail/a_id/615
Users browsing this forum: No registered users and 42 guests
