 Post subject: Help - CE Log Error ST 9160827AS
PostPosted: February 14th, 2012, 13:02
Sirs/Madam :mrgreen:
Have This Case .Guy Needs Data .I am having a tough time with this one .Checked Terminal And Saw it has a Ce Log Issue .This is Saturn Family As Per 5.5 Version of Seagate Doctor .The Following is The Process i have used .
1 : Connected the HDD to Tool
2 : Load From HDD
3 : In Other Operations "Switch To Level F "
4 : To To Boot Tab and Select Path Of ATA Module [ Module Was already Saved Earlier ]
5 : Press the Load ATA Buttom
No Luck .I there something Wrong i am doing Here .I Used Ce Log Repair Solution Few Months back and the only thing i see changed in the software .Shall i try in some older version ?
PS : When you Press the Load ATa Button do you See the Progress Bar I do not see that .After many minutes it says completed but nothing happens
 Post subject: Re: Help - CE Log Error ST 9160827AS
PostPosted: February 14th, 2012, 16:10
Did u run selfscan ?
PostPosted: February 14th, 2012, 18:55
Hope not. Customer needs data.
PostPosted: February 15th, 2012, 1:54
lol,
why will i run selfscan ? .i need data :D for the client
PostPosted: February 15th, 2012, 7:38
"CE log issue" as in pending bug?
Data Recovery Cape Town
PostPosted: February 15th, 2012, 12:30
If you don't have pc3k to load a task from a loader you could try t4e but if you have bads in sa it could cause more problems for you
Users browsing this forum: Google [Bot], michael chiklis and 106 guests
cron
