 Post subject: Toshiba MK2555GSX
PostPosted: March 20th, 2012, 13:42
Hello!
I have both drives with the same problem ( spins up fine, normal calibration and no strange sound )
But on the status register it shows busy.
Has any one has any experience with similar problem?
Thanks in advance for any suggestions.
Best regards,
 Post subject: Re: Toshiba MK2555GSX
PostPosted: March 20th, 2012, 13:46
Sure there are not very quiet "bzz bzz" noises?
I mean VERY quiet.
And after 5 minutes or more come DRDY and ID?
PostPosted: March 20th, 2012, 13:53
pcimage wrote:
Sure there are not very quiet "bzz bzz" noises?I mean VERY quiet.
Sure. Its not a stiction sir, its spin up fine.
Yes it come DRDY but not ID. And no access to anything.
PostPosted: March 20th, 2012, 15:44
This has worked for me with some Toshiba models that stay busy:
1) Find donor drive (hda+pcb)
2) Connect to PC3k, Power On, Enter PC3K Toshiba utility
3) Power off
4) Put patient PCB on donor HDA
5) Power on
6) Wait for ready (may take a few minutes)
7) Put drive in Standby
8) Swap HDA to patient
9) "Recalibrate"
10) Try to recover data: Data Extractor, Head map, Image
Hope this helps!
PostPosted: March 20th, 2012, 16:52
No, not stiction.
I have seen loads of these model that have bad/weak heads.
PostPosted: March 22nd, 2012, 9:36
pcimage wrote:
No, not stiction.I have seen loads of these model that have bad/weak heads.
Yes sir I know what you mean with ( very quiet ), it is very common with modern Toshiba drives ( 320, 500....etc ). Slow detection and too many delayed sectors because of bad/weak head/s.
But this drive is different.
Anyway, thank you sir for trying to help. :)
Users browsing this forum: Google [Bot] and 67 guests
