 Post subject: Seagate Momentus 5400.2
PostPosted: March 28th, 2012, 4:55
Ok, so i have this hard-drive that won't spin up.
model: st98823as
sn: 5pk341qf
PCB: 100397877 Rev B
The problem seems to be a fried smd near the sata power connector.
The smd has a stripe on one side, and "KEU" marking, with a small dot under the "U", but i don't know if it's a capacitor or a diode.
Can anyone tell me what "KEU" means? Couldn't find anything on SMD Marking Codes pdf found on google.
 Post subject: Re: Seagate Momentus 5400.2
PostPosted: April 2nd, 2012, 15:35
Upload a pic.
"A problem is only an opportunity in work clothes"
Www.sandiegorecovery.com
PostPosted: April 3rd, 2012, 4:35
"KE" is the marking code for a 5V TVS diode. If it's shorted, and if it's connected between the +5V supply and ground, then remove it.
PostPosted: April 3rd, 2012, 4:50
model: st98823as
sn: 5pk341qf
Well,
Upload a PIC and Do You Have A Soldering Iron ? Also Do You Know How To USe It :mrgreen:
PostPosted: April 3rd, 2012, 14:59
Thaks for reply! In the meantime i found out that, indeed, it's a 5V TVS diode.
I removed it so i was able to backup all the data.
Being hard to find such a diode i left the hdd without it....
all the best
Users browsing this forum: Google [Bot] and 63 guests
