 Post subject: general question / WD Caviar Green
PostPosted: April 8th, 2012, 8:02
Hi
First post... I had a look through the general area and FAQ, couldn't find anything relevant...
It's a fairly general question really - I had my PC fail yesterday. I diagnosed it as a power supply failure, and was pleased when the new P/S I bought worked OK. However... blowing the P/S seems to have damaged a HDD, a WD Caviar Green 500gig, and it will not now power up. Tried it in a couple of PCs, different power cables, different SATA cables, and in an external enclosure. Nothing.
So I assume it is dead. But - is it possible that it's just blown the electronics (or whatever I should call them) and that the data on the media would still be accessible and recoverable if I could somehow get the device to power up? And if so how feasible would that be - not for an idiot like me, but presumably by a specialist? Or is it more likely the entire device has been fried?
Any guidance welcome!
 Post subject: Re: general question / WD Caviar Green
PostPosted: April 9th, 2012, 9:09
First you have to unscrew the PCB. Then post a picture of the PCB here, maybe its TVS problem and someone here could help you.
PostPosted: April 9th, 2012, 10:00
Well, I don't have the tool to unscrew the PCB... all I really want to know is , given the circumstances of the HD failure, how likely is it that the data would be recoverable by a suitably skilled technician?
PostPosted: April 9th, 2012, 10:22
It depends on the failure. ( i.e Precise diagnosis required )
PostPosted: April 10th, 2012, 0:00
Highly likely if no further tampering actions with the drive are taken by someone unqualified.
PostPosted: April 10th, 2012, 0:13
As long as there is no media damage, successful recovery is very likely.
http://www.datasaversllc.com
PostPosted: April 10th, 2012, 3:10
OK, thanks for that. Much appreciated.
Users browsing this forum: Google [Bot] and 62 guests
