I have a 320GB Seagate Barracuda 7200.10 that has failed on me and I would very much like to try and recover the data on it. I have attached a picture of the drive which includes the model number, firmware version, etc.
I purchased a Nokia CA-42 cable which I was able to use to connect to the serial interface on the back of the drive and get into the diagnostic/firmware terminal. I was hoping someone could help me with commands to run to figure out what exactly is wrong and perhaps if there is a way I could fix it myself.
Here is what prints out when the drive is powered up:
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
Buzz HM SFI
(P)SATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=47 at ffffffff.00.022b
Failed sys sect. write! Nwt Er 00 RdWr 15c4b.00.022b
DiskAccess ReadSector EC=47 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>
Sending Ctrl+A shows:
T>Eng Rev = .0GB
Compat/Hardware = .6D1
GALAXY2D - 2_Disk 3.AAE 11-03-06_16:41 AAE,GX_2D_4H_S,3A
CERT Rev = .0B9
NONE
Mask Rom Rev = S-6D
Orig Code = AAE3A0 TONKA2_GX_3A0.0GB.0B9
T>
Sending Ctrl+L shows:
T>GALAXY2D - 2_Disk 3.AAE 11-03-06_16:41 AAE,GX_2D_4H_S,3A
Built for GALAXY2D,PITKIN,Redback,TI1810 PreAmp,Agere7531 PreAmp,McKinleyDT,2DiR
As you can see I learned some commands from some basic internet research but I was hoping I could get some feedback before trying all sorts of weird things. The other two things I tried were resetting the G-list (T>i4,1,22) and clearing SMART area (1>N1) -- I know what SMART is, I think, but not G-list. Neither of these changed anything. The drive spins up and sounds fine, no weird noises.
I don't think I can afford a data recovery service, but I guess I would consider it. The most critical things are a password safe and some past tax returns/financial documents.
Thanks in advance for any help someone can provide.
