 Post subject: problem with samsung disk
PostPosted: April 4th, 2012, 13:06
hello all!
I have a samsung hard disk that has suddenly started to do the classic sound of the crash of heads and no longer wants to start
start- tak tak tak - pause - tak tak tak tak - pause - and continues until you turn it off.
(number of tak is random, sometimes it's just 1 or 2 or 3-4 consecutive)
is certainly a problem of heads or may be the controller of the PCB that can be broken?
thank you very much
 Post subject: Re: problem with samsung disk
PostPosted: April 4th, 2012, 13:09
You have the best Samsung expert right there in Italy BlackST. If you need help on this before you attempt to do anything that should not be done contact him. He will help you out for a very reasonable price on this one. He is not far so this should be easy for you to get help from him.
Iorana Haraharaini
PostPosted: April 5th, 2012, 3:38
@Darknight, it sounds like you are describing a stiction fault (heads stuck to platters), or a seized spindle bearing.
PostPosted: April 5th, 2012, 4:06
@fzabkar, tak tak tak sound is never a sticktion problem. sticktion sounds like 'bleep bleep bleep' :lol:
The sound the OP is describing is definately a head problem and it's the sound you get when the headstack sways from one side to the other and hits the end stops.
PostPosted: April 5th, 2012, 14:06
thanks for your kind answers ....
I do a video with sound that makes the hard disk to identify the problem?
If I provide a clean room is possible to replace the heads?
there is the possibility that it may be the disk controller pcb?
how can I get in touch with blackst?
thanks
PostPosted: April 5th, 2012, 14:40
BlackST is here on the forum. Not sure you can send him a PM. I will show him that you are looking to get in touch with him and see if he will send you a PM on this one.
As for you to change out this out with no experience you will not make it. Better to let him do this one for you if your data means anything to you.
Iorana Haraharaini
PostPosted: April 5th, 2012, 15:00
thanks a lot,
if I can get in touch with BlackST is the best solution to solve the problem without too much risk.
PostPosted: April 5th, 2012, 15:06
It's not possible to send PMs until you have done some activity so I will PM you later :)
PostPosted: April 5th, 2012, 15:59
thanks black!
PostPosted: April 29th, 2012, 17:29
news for me black? can we talk of my problem in pm? i can't send message to you :-(
PostPosted: April 29th, 2012, 17:47
Check your PM inbox !
PostPosted: June 2nd, 2012, 13:13
ciao Black,
ho risposto al tuo messaggio privato ma forse non l'hai ricevuto.
mi potresti dare una cortese conferma se รจ arrivato o meno?
grazie
Users browsing this forum: skinbob and 87 guests
